Looks like the same issue we encountered when we went live in January. Hereās what i documented at the time.
The problem was that any amount numbers were not formatting correctly in the file ā numbers with trailing zeros had the zeroes truncated, and numbers with non-zero trailing numbers were not using the correct number of spaces in the file.
The solution seems to be to change the āMultiplierā field on the field mapping table from 1 to 100 (despite the article above indicating to change from 100 to 1.
