Reply To: Adding new vendor from Vancouver WA USA
    August 29, 2024 at 9:41 am
    Check the zip code table (You can use the drop-down lookup from the CITY or ZIP code field on the vendor card). There is probably an entry there for Vancouver, BC, Canada. You can either delete that OR add an entry for Vancouver, WA. If you add Vancouver, WA, then when entering Vancouver into the CITY field on the Vendor Card, BC will pop-up a list of all Vancouver entries so that you can choose the correct one.
