Reply To: Tracking SN & Lot
    February 21, 2024 at 5:10 pm
    Hello Elizabeth!
    The textbook answer is to create a new item with tracking turned on or rename the current item and then recreate the item number you are using. Of course, that will split your history and an item rename can take a long time.
    A developer can help you turn tracking on but first you must remove all inventory and remove the item from all open orders, etc. After that a developer can write a quick process report to turn on tracking. Then you can add all of your inventory back into the system, including tracking information that was not in the system before and then you can add the item back to any orders.
