I just tested this in BC14 and BC22 and confirm that they behave differently. BC22 does not allow different column layouts as far as I can tell for different saved filtered lists.
In BC14 (using the RTC), I was able to have a different column layout for different saved filtered views. After creating the views I logged into the BC14 Modern (web) client and the column layouts were still different for my two different saved views from the same page. I did not try creating the saved filtered views in the modern client.
Login
Block Member?
See blocked member's posts
Mention this member in posts
Invite this member to groups
Message this member
