Reply To: How do you handle an environment for testing? (On-Prem)
    February 13, 2024 at 8:20 pm
    BC14 On Prem.
    Our production and test environments share a Service Tier Server and a SQL server, but we have different SQL databases for both.
    To refresh test, I use a RapidStart Configuration to export some setup tables from test that contain file export paths, etc., then a take a producion backup, restore it to the test SQL database and then import my setup files back to test using the configuration packages.
    I have another business unit that I am supporting on NAV 2017. The have separate Service Tier and SQL server for production and test. We refresh test using the same process that I described above.
