Reply To: Flowfields only when not blank
Jonathon – Here is my developers reply as a sample…
If you have a flowfield and you want the drilldown to show a different set of data you can write code in the ondrilldown trigger.
This example has a flowfield for the sum of the Item quantity, but if you drill down ā youāll get the sales orders. I didnāt do anything but filter on the order, but you can see how it is as an example. This is a basic sample based on what I understand is the ask. It may be done differently with different requirements.
table 50100 “DEV New Table”
Caption = ‘New Table’;
DataClassification = CustomerContent;
fields
field(1; “Item No.”; Code[20])
Caption = ‘Item No.’;
TableRelation = Item;
field(15; “Quantitiy”; Decimal)
CalcFormula = sum(“Item Ledger Entry”.Quantity where(“Item No.” = field(“Item No.”)));
Caption = ‘Quantity’;
DecimalPlaces = 0 : 5;
Editable = false;
FieldClass = FlowField;
keys
key(PK; “Item No.”)
Clustered = true;
page 50100 “DEV New Page”
ApplicationArea = Basic, Suite;
Caption = ‘New Page’;
Extensible = false;
PageType = List;
SourceTable = “DEV New Table”;
UsageCategory = Lists;
layout
area(Content)
repeater(DevControl1)
field(Item_No; Rec.”Item No.”)
field(Quantitiy; Rec.Quantitiy)
trigger OnDrillDown()
var
SalesHeader: Record “Sales Header”;
begin
SalesHeader.SetRange(“Document Type”, “Sales Document Type”::Order);
Page.RunModal(Page::”DEV Sales List”, SalesHeader);
end;
page 50101 “DEV Sales List”
Caption = ‘Sales List’;
Editable = false;
Extensible = false;
PageType = List;
SourceTable = “Sales Header”;
UsageCategory = None;
layout
area(Content)
field(DocumentType; Rec.”Document Type”) { }
field(No_; Rec.”No.”) { }
field(ExternalDocumentNo; Rec.”External Document No.”) { }
Steve
