The system is using the routing times to calculate how long the production order will take to complete the quantity ordered. So if you change the start date, the end date is adjusted for the calculated time. Likewise, changing the end time will affect the start date the same amount of time. End date is the same as due date. I don’t believe the order date should be affected.
Login
Block Member?
See blocked member's posts
Mention this member in posts
Invite this member to groups
Message this member
