Reply To: NAV 2018 Lanham EDI 856 with Status Codes
    May 20, 2023 at 1:02 pm
    <<If you are referring to the EDI855 (Purchase Order Acknowledgment), then you need to code it as E_SLSASN to use the status codes>>
    CORRECTION:
    If you are referring to the EDI855 (Purchase Order Acknowledgment), then you need to code it as E_ADVPOA to use the status codes
