Zoho Desk connector to Power BI desktop
  • Zoho Desk connector to Power BI desktop
    Posted by DSC Communities on February 4, 2019 at 2:17 am
    • Elizabeth Tachjian CPA
      February 4, 2019 at 2:17 AM
      Any ideas on how to connect Zoho Desk to Power bi Desktop?Ā  Not the same as Zoho CRM.
      Cheers
      Elizabeth
      Business Intelligence Dashboards Developer
      Analytics Realtime
      Melbourne [VIC]
      0417457054
    • Tony McGovern
      February 5, 2019 at 9:00 AM
      Elizabeth — Zoho products allow applications to authenticate to their APIs using OAuth 2.0. This means you’ll have to build a custom connector in Power BI.
      My company uses Zoho products and I’ve built custom connectors in both Flow and Power BI to our data in Zoho Books, Zoho CRM, and Zoho Campaigns. I quickly looked at the API documentation for Zoho Desk and that API authenticates the same way as other Zoho products. And these APIs implement the “authorization code” grant type, which is a way for your application to request tokens from the authorization server.
      Here’s a sample custom connector for the DataWorld API, which also uses OAuth 2.0 authentication with an authorization code grant type. This other custom connector connects to Dropbox, which again, also uses OAuth 2.0 with the same grant type. (Both examples were created by developers on the Power BI product team.)
      You can use these examples as templates for your Power BI custom connector to Zoho Desk.
      Let me know if you run into any problems; I’m happy to help.??
      Tony McGovern
      co-Founder & Data Scientist
      em•data Inc.
      tony@emdata.ai
      (202) 594-6194
      February 7, 2019 at 1:18 AM
      Hi Tony,
      How long did it take you to develop the custom connector?Ā  Will I need an ODBC driver to connect the custom connector with Power BI desktop.
      Thank you for time.
      Elizabeth Tachjian
      Analytics Realtime——————————————-
    • Tony McGovern
      February 8, 2019 at 10:26 AM
      Elizabeth — You don’t need an ODBC driver to connect the custom connector. With Zoho products, you just need to call the API with Web.Contents.
      If you’re not familiar with custom connectors, particularly those that authenticate with OAuth 2.0, prepare to spend a few days or even weeks figuring it out. Luckily, this GitHub custom connector tutorial walks you through the basics. And once you get the hang of that, it’s not that challenging to swap out the GitHub authentication parameters with Zoho parameters. In other words, the flow to authenticate to both the GitHub and Zoho APIs are similar.
      Note: if you’ve not created a custom connector before, you’ll need to read and understand the prerequisites first.
      If you start down this path, I’m more than happy to help you through it. Just give a shout.
      Tony McGovern
      Emdata Inc.
    • Diego Carballo
      September 6, 2019 at 4:44 PM
      Hello Tony, I went down this path using the DropBox example as an example, and I paste below what I have. I am stuck getting Login Failed , can’t parse Query String. Any ideas what I could be doing wrong ? Regards,
      // This file contains your Data Connector logic
      section ZohoDesk;
      // Data Source UI publishing description
      ZohoDesk.Publish = [
      Beta = true,
      Category = “Other”,
      ButtonText = { Extension.LoadString(“ButtonTitle”), Extension.LoadString(“ButtonHelp”) },
      LearnMoreUrl = “https://powerbi.microsoft.com/”,
      SourceImage = ZohoDesk.Icons,
      SourceTypeImage = ZohoDesk.Icons
      ZohoDesk.Icons = [
      Icon16 = { Extension.Contents(“ZohoDesk16.png”), Extension.Contents(“ZohoDesk20.png”), Extension.Contents(“ZohoDesk24.png”), Extension.Contents(“ZohoDesk32.png”) },
      Icon32 = { Extension.Contents(“ZohoDesk32.png”), Extension.Contents(“ZohoDesk40.png”), Extension.Contents(“ZohoDesk48.png”), Extension.Contents(“ZohoDesk64.png”) }
      client_application = Expression.Evaluate(Text.FromBinary(Extension.Contents(“client_application”)));
      windowWidth = 1200;
      windowHeight = 1000;
      TokenMethod = (code, grant_type) =>
      let
      Response = Web.Contents(“https://accounts.zoho.com/oauth/v2/token”, [
      Content = Text.ToBinary(Uri.BuildQueryString([
      client_id = client_application[ClientId],
      client_secret = client_application[ClientSecret],
      grant_type = grant_type,
      code = code,
      redirect_uri = client_application[CallbackUrl]
      Parts = Json.Document(Response)
      in
      Parts;
      StartLogin = (resourceUrl, state, display) =>
      let
      AuthorizeUrl = “https://accounts.zoho.com/oauth/v2/auth?” & Uri.BuildQueryString([
      response_type = “code”,
      state = state,
      scope = “Desk.tickets.READ”,
      redirect_uri = client_application[CallbackUrl]])
      in
      LoginUri = AuthorizeUrl,
      CallbackUri = client_application[CallbackUrl],
      WindowHeight = windowHeight,
      WindowWidth = windowWidth,
      Context = null
      FinishLogin = (Context, CallbackUri, state) =>
      let
      Parts = Uri.Parts(CallbackUri)[Query]
      in
      TokenMethod(Parts[code], “authorization_code”);
      GetDirectory = () =>
      let
      source = Web.Contents(“https://desk.zoho.com/api/v1/tickets?include=contacts,assignee,departments,team,isRead”, [
      Headers=[#”Content-Type”=”application/json”]
      json = Json.Document(source),
      cursor = json[cursor]?,
      table = Table.FromList(json[entries], Splitter.SplitByNothing(), null, null, ExtraValues.Error)
      in
      table;
      Refresh = (resourceUrl, refresh_token) => TokenMethod(refresh_token, “refresh_token”);
      [DataSource.Kind=”ZohoDesk”, Publish=”ZohoDesk.Publish”]
      shared ZohoDesk.Contents = () => GetDirectory();
      ZohoDesk = [
      Authentication=[OAuth=[StartLogin=StartLogin, FinishLogin=FinishLogin, Refresh=Refresh]]
      Diego Carballo
      +54 1147819300
    • Alexander Ferguson
      June 1, 2020 at 9:37 AM
      Hi Tony – thanks for your contribution in this thread, this has helped me greatly in trying to connect to Zoho CRM. I’m trying to connect to Zoho CRM API and I am receiving an error after logging into Zoho through my custom connector, I hope you can help as my connector seems 90% complete, just missing the final step! (code below).
      Error message: [DataFormatError] We couldn’t parse your query string as it was improperly formatted
      section Zoho_Connector___V1.1;
      // TODO: add your client id and secret to the embedded files
      client_id = “XXXXX”;
      client_secret = “XXXXXX”;
      redirect_uri = “https://oauth.powerbi.com/views/oauthredirect.html”;
      windowWidth = 800;
      windowHeight = 800;
      //Oauth base url for
      OAuthBaseUrl = “https://accounts.zoho.eu/oauth/v2/auth?”;
      [DataSource.Kind=”Zoho_Connector___V1.1″, Publish=”Zoho_Connector___V1.1.Publish”]
      shared Zoho_Connector___V1.1.Contents = () =>
      let
      navTable = Web.Contents(“https://www.zohoapis.eu/crm/v2/Leads”)
      in
      navTable;
      // Data Source Kind description
      Zoho_Connector___V1.1 = [
      Authentication = [
      // enable both OAuth and Key based auth
      OAuth = [
      StartLogin = StartLogin,
      FinishLogin = FinishLogin,
      Refresh=Refresh
      Label = Extension.LoadString(“DataSourceLabel”)
      Zoho_Connector___V1.1.Publish = [
      Beta = true,
      Category = “Other”,
      SourceImage = Zoho_Connector___V1.1.Icons,
      SourceTypeImage = Zoho_Connector___V1.1.Icons
      // OAuth2 flow definition
      let
      AuthorizeUrl = OAuthBaseUrl & Uri.BuildQueryString([
      scope = “ZohoCRM.modules.all”,
      client_id = client_id,
      redirect_uri = redirect_uri,
      state = state,
      access_type = “online”])
      in
      CallbackUri = redirect_uri,
      Context = null
      FinishLogin = (context, callbackUri, state) =>
      let
      Parts = Uri.Parts(callbackUri)[Query]
      in
      let
      Response = Web.Contents(OAuthBaseUrl & “/token”, [
      grant_type = “authorization_code”,
      client_secret = client_secret,
      code = code
      Headers=[#”Content-type” = “application/x-www-form-urlencoded”,#”Accept” = “application/json”]]),
      in
      Parts;
      Zoho_Connector___V1.1.Icons = [
      Icon16 = { Extension.Contents(“Zoho_Connector___V1.116.png”), Extension.Contents(“Zoho_Connector___V1.120.png”), Extension.Contents(“Zoho_Connector___V1.124.png”), Extension.Contents(“Zoho_Connector___V1.132.png”) },
      Icon32 = { Extension.Contents(“Zoho_Connector___V1.132.png”), Extension.Contents(“Zoho_Connector___V1.140.png”), Extension.Contents(“Zoho_Connector___V1.148.png”), Extension.Contents(“Zoho_Connector___V1.164.png”) }
      Thank you!
      Alexander Ferguson
    • PS D
      June 13, 2022 at 1:54 AM
      Hey Alexander Ferguson, Have you figured out the Zoho CRM connection.
      I would be really thankful to you if please share some light on the rectification you must have done to get through the connection.
      in case you can share some sample code or at least how the problem have been resolved.Ā
      Cheers!!!
      PS D
      Cofounder
    • Rafael Guerrero
      February 5, 2019 at 1:10 PM
      Hi Elizabeth: You have a few options. For example, we had a similar request for one of our clients. They needed reports from Zoho Desk and the reporting engine was PowerBI.Ā  What we did is pull the data from Zoho Desk via the REST API framework and load the data into an internal reporting database, that refreshed everyday.Ā  Once the data was in the database it was fairly straightforward to create the reports.
      Good luck; feel free to message me if you need any assistance.
      Rafael Guerrero
      Gnnovation, LLC.
      Denton TX
      2145297050
    • David de la Nougerede
      October 11, 2019 at 3:32 PM
      HiĀ Rafael
      Is this a service you sell. I am very interested.
      Can you get back to me asap
      ME19 4YU
    • Daniel Demers
      July 1, 2019 at 2:05 AM
      Hi Elizabeth,
      Did you have any luck connecting Power BI to Zoho? I’ve just begun working with a company that uses Zoho after being on Dynamics CRM for 10 years and am wondering what the easiest/best way to connect Power to Zoho would be.Ā
      Daniel Demers
      Chief Digital Information Officer
      Dan
      61423566444
      July 1, 2019 at 7:05 PM
      Hi Daniel,
      I connected Power BI desktop and Zoho CRM using Cdata ODBC Driver.
      Warm Regards
      Elizabeth Tachjian
      Analytics Realtime
      elizabeth@analyticsrealtime.com.au
      Analytics Realtime
      Melbourne [VIC]
      0417457054
    • Hasham Niaz
      July 3, 2019 at 7:57 PM
      Hi Eliz,
      CData connector is the paid one right ?
      Hasham Bin Niaz
      Director Data & Analytics
      Karachi, Pakistan
    • Tamara Tsyhan
      December 20, 2021 at 4:56 AM
      Hi Daniel,
      ODBC drivers could be a good solution to the problem, but many of them are quite costly. If you are looking for an effective solution for good money try Devart ODBC Driver for Zoho CRM
      Hope you will find it useful
      Tamara
      Tamara Tsyhan
      Product Marketing Manager
    DSC Communities replied 7 years, 4 months ago 1 Member · 0 Replies
The discussion ‘Zoho Desk connector to Power BI desktop’ is closed to new replies.
