Multiple Measures with Tabular Editor
  • Multiple Measures with Tabular Editor
    Posted by DSC Communities on November 7, 2020 at 8:51 am
    • Jesse Hancock
      November 7, 2020 at 8:51 AM
      I was hoping to find if anyone else has a solution to making multiple measures at once,
      Can i create three measures at once without using a calculation group?
      I would like to define more than 50 measures at once, each with differing dax scripts. Because there is no consistency, i dont want to use a calculation group.
      Can i do this in PBI or tabular editor?
    • Vincent Lacomme
      November 8, 2020 at 9:19 AM
      Hi Jesse,
      As far as I know, you can use tabular editor. to duplicate and edit measures much faster than in PBI. You would have to create each measure one by one.
      There is also the possibility to create scripts in Tabular editor. These scripts could possibly help to automate this task.
      Vincent L.
      Chartered accountant – Expert-comptable
    • Vishesh Jain
      November 9, 2020 at 6:23 AM
      Hi ?,
      Here is an article by in which you can use tabular editor to create multiple measures at once.
      https://exceleratorbi.com.au/introduction-to-tabular-editor-for-business-users/
      With that being said, there is scripting required in some language other than DAX or M and also, the file created will be a PBIT (Template) file.
      So please have a look at the article and I hope this helps.
      Thank you,
      Vishesh Jain
      Owner
      VR Construction
    • Jesse Hancock
      November 13, 2020 at 3:45 AM
      Thanks, this was super useful!
      Jesse Hancock
      2010
      400256732
    • Vishesh Jain
      November 23, 2020 at 1:26 AM
      Glad to help!,
      If my suggestion solved your problem, please can you mark it as the best answer, so that others can reach the solution faster.
      Thank you,
      Vishesh Jain
      Owner
      VR Construction
The discussion ‘Multiple Measures with Tabular Editor’ is closed to new replies.
