Print Multi check for 1 employee
  • Print Multi check for 1 employee
    Posted by MARY MALLAZZO on August 23, 2022 at 3:58 pm
    • Mary Mallazzo
      August 23, 2022 at 3:58 PM
      Hello
      Is it possible to print multi checks to 1 employee in the same check run?
      Thank you
      Mary Mallazzo
      Fromkin Brothers
      Edison NJ
    • Michael Gummel
      August 24, 2022 at 8:41 AM
      Ā  the answer kind of depends on how you are generating the checks.Ā  Ā if they are being paid thru ap, then you would need multiple invoices for the employee.Ā  Ā Depending on the version of GP you are using, there is a setting in the Vendor master to allow for multiple invoices per check or one check per invoice — you would need to set that appropriately at the vendor level, then when you create the check batch, there is an option to use vendor setting.Ā  Ā If you are on an older version of GP, then you would need to ONLY have the employees that you want multiple checks for in the check batch and select the option (on the build batch) to have one check per invoice.Ā  Ā I hope that helps, if not clear please reach out to me and I can explain better or show you what i’m talking about.?
      Michael Gummel
      Prod Engineer
      Paradigm Technology Consulting
      Allentown NJ
      mtgummel@ptcsolutions.com
    • Mary Mallazzo
      August 24, 2022 at 10:48 AM
      Michael
      These are employees not vendors.Ā  Payroll checks not A/P checks.
      It appears that it is not possible to print multi P/R checks for the same employee within the same check run.
      Mary Mallazzo
      Fromkin Brothers
      Edison NJ
    • Christine Olsen
      August 25, 2022 at 7:53 AM
      That is correct Mary! There is no way to run two separate checks in the same payroll build for one employee. You would have to do 2 separate builds.
      Christine Olsen
      Payroll Specialist
      The Schaefer Group, Inc.
      Beavecreek OH
    MARY MALLAZZO replied 4 years, 2 months ago 1 Member · 0 Replies
The discussion ‘Print Multi check for 1 employee’ is closed to new replies.
