Unfortunately, it appears that the Automatic Tax Update is no longer functional. The assumption I have is because Terry Retired and she had maintained this on a PC she had at her desk. I assume this got powered off when she retired and this process will not work going forward and will need to rely on the manual approach.
The manual approach is just as simple but a couple extra steps.
a. We can see the Ohio update was released in round 6.
2. You can then install it two ways.
a. Open the Payroll Update Method window.
i. Dynamics GP | Maintenance | U.S. Payroll Updates | Check for Tax Updates.
b. Mark the Manual Radial Button and click Next.
c. Click the Folder button and path out to the location you saved the download to and select the folder location.
d. Click Process.
i. One thing to keep in mind is this process only works once per download. If you already ran it and want to do it again, you need to download it again.
1. Not sure why this happens but is an odd thing I have noticed. š.
e. Click Finish.
3. Now you can check the Payroll Tax Setup window and verify the date of the Last Tax Update to verify it was successful.
a. Administration >> Setup >> System >> Payroll Tax
