The most common cause of this is someone changing the item type directly in the SQL database. The user interface will not allow this change. It was probably setup as an inventory item originally. Then there was activity (receipts, adjustments, etc.). Then it was changed to a service item.
Here are a couple solutions…
– Use the PSTL tool to change Item Number to something else. Create a new (service) Item using the original item number. Now you have a blank slate (with not quantities).
– Find the culprit who changed the item type and have them wipe out the quantities on the inventory tables.
