Vendor list with bank accounts
  • Vendor list with bank accounts
    Posted by Unknown Member on November 4, 2020 at 3:05 pm
    • Susan Bratek
      November 4, 2020 at 3:05 PM
      Can anyone tell me how I can generate a report showing all Vendors with their bank account and routing numbers?
      Susan
      Susan Bratek
      Accountant
      Allied Motion Technologies Inc.
      Amherst NY
    • Ian Waring
      November 5, 2020 at 3:16 AM
      Hiya,
      I have a PowerBI report that sees all of this (bar the routing/sortcode) in the CustomersV2 or CustomersV3 Entity (has all the tax data in there too.
      I’ve not found where the routing number is stored though (ran out of time with other priorities nagging at me :-)).
      hth.
      Ian W.
      Ian Waring
      Head of Finance Systems & Projects
      Jisc
      Bristol
    • Mark Bailey
      November 5, 2020 at 4:11 AM
      Hi Susan,
      There is no standard report that gives you this. The Bank data is held in a separate table VendBankAccount which needs to be joined to VendTable to produce the report.
      There are 2Ā  data entities VendorsV3 and VendBankAccount you can use these to extract the data through data management and then put the report together outside of the system through. (I.e. Vlookups in excel to return the Bank account & Sort Code.)
      Alternatively you could set up an Electronic report which you can configure to do the above for you so you just run a report from within the system.
      Hope that helps šŸ™‚
      Mark Bailey
      Application Consultant
      Annata
      Portsmouth
    • Ian Waring
      November 5, 2020 at 4:25 AM
      Apologies – Mark is correct, Vendors entity, not customers. Take 100 lines Ian!
      Ian Waring
      Jisc
      Bristol
    • Phil Dawson
      November 5, 2020 at 11:05 PM
      Hi Susan,
      Another option to the above is to open the vendor bank account form. If you are using D365 just add &mi=vendbankaccounts to your URL, so
      https://xxxx.operations.dynamics.com/?cmp=xxxx&mi=vendbankaccountsĀ  (where xxxx is your instance).
      From here you can see all the vendor bank accounts.Ā  To get the data out you will need to personalise the form and add the routing number and account number to the pane on the left, you can then use export to excel to pull all the records out.
      Cheers
      Phil
      Phil Dawson
      Sunpork Fresh Foods Pty Ltd
    Unknown Member replied 5 years, 7 months ago 1 Member · 0 Replies
The discussion ‘Vendor list with bank accounts’ is closed to new replies.
