How do you reopen the inventory after you have closed it for the month.
  • How do you reopen the inventory after you have closed it for the month.
    Posted by DSC Communities on March 20, 2018 at 12:32 pm
    • Don Newcomer
      March 20, 2018 at 12:32 PM
      How do you reopen the inventory after you have already closed it for the month?Ā  I have one entry that needs to be posted to February.
      Don
      Don Newcomer
      Mooney International Corp.
      Kerrville TX
    • Don Newcomer
      March 21, 2018 at 9:58 AM
      I appreciate the feedback from everyone.Ā  Thank you for taking the time to respond.Ā Ā
      Don
      Don Newcomer
      Kerrville TX
    • Troy Jones
      March 21, 2018 at 7:12 AM
      ?Don:
      Select IM – Periodic – Closing and adjustment.Ā  Select the “close” that you want to reverse and click the cancellation button in the menu.Ā  NOTE – if you have subsequent closes after the desired close, you have to cancel all closes after and backwards.
      Also – make sure your GL periods are open as the close makes adjustments in the period being cancelled when it undoes that action.
      Troy Jones
      Functional Systems Architect / Consultant
      Hi-Vue Solutions, LLC
      Akron OH
    • Ankit Modi
      March 21, 2018 at 3:56 AM
      System will not allow to reopen the inventory after closing.
      Still you can use “Cancellation” option on for the last active inventory closing. It will cancel the closing and reverse all closing transaction & adjustments.
      Moreover, cancellation of inventory cannot be applied on selective items/groups. It will cancel inventory closing for last active closing.
      Once you have done with your backdated entry, you have do close the inventory again.
      Ankit Modi
      Project Manager – AX/D365FO
      Indusa Infotech Services Pvt Ltd.
      Ahmedabad
    DSC Communities replied 8 years, 2 months ago 1 Member · 0 Replies
The discussion ‘How do you reopen the inventory after you have closed it for the month.’ is closed to new replies.
