DMF/DIXF Product category hierarchy: Import does not work
  • DMF/DIXF Product category hierarchy: Import does not work
    Posted by DSC Communities on July 18, 2019 at 10:09 am
    • Daniel Zook
      July 18, 2019 at 10:09 AM
      Environment: AX R3 CU 13 with all hotfixes
      Has anyone else tried to use the standard “Product category hierarchy” entity to import a product category hierarchy?Ā  All my attempts fail with errors like this:
      Results. Record (‘BKA-0’) . Root node already exists
      Results. Record (‘BKS-0’) . Root node already exists
      I even setup an export using this same entity and then used the file to import back into AX (after deleting the hierarchy) and it still fails… in other words, it can’t even work with the data that the same entity exports from itself.
      Has anyone else experienced this?Ā  Do you know how to fix it?
      Thanks.
      Daniel Zook
      Director of IT
      Lehman’s
      Dalton OH
    • Yvan Charbonneau
      July 19, 2019 at 6:42 AM
      Hi Daniel,
      I had the same errors the first time I used the entity but managed to work around it by unchecking the business validations checkbox on the entity. Ā I was then able to import successfully.
      Best regards,
      Yvan Charbonneau
      Senior Director of Information Systems and Supply Chain
      Laboratoire Riva Inc
      Blainville QC Canada
    • Daniel Zook
      July 23, 2019 at 9:48 AM
      Thanks for the reply.Ā  I’ve tried with with “business validations” enabled and disabled, and it doesn’t make a difference for me.
      If you or anyone else has more suggestions, I would appreciate it if you would share.Ā  Thanks in advance.
      Daniel Zook
      Director of IT
      Lehman’s
      Dalton OH
    • Daniel Zook
      July 23, 2019 at 9:53 AM
      One other thing I forgot to ask: What fields do you populate in the staging table?Ā  I have a feeling that I’m missing something.
      Thanks.
      Daniel Zook
      Director of IT
      Lehman’s
      Dalton OH
    • Yvan Charbonneau
      July 23, 2019 at 10:20 AM
      Hi Daniel,
      I’m only importing the Category hierarchy ID, Category code and description.Ā  Just in case, I’m using the standard DMFEcoResCategoryEntity.
      Best regards,
      Yvan Charbonneau
    • Daniel Zook
      July 23, 2019 at 11:38 AM
      Using that entity did the trick.
      It doesn’t work if you try to use theĀ DMFEcoResCategoryHierarchyEntity… at least not the way I was trying to use it…. šŸ™‚
      Thanks again for your help.
      Daniel Zook
      Director of IT
      Lehman’s
      Dalton OH
    • Shirley Adams
      July 24, 2019 at 11:12 AM
      We used the standard entity (this is D365 but should be the same in AX2012 R3).Ā  You need parent category on each line or it won’t know to put in a hierarchy type view.Ā  Here are the first few lines when we imported a public sector for NIGP codes:
      PRODUCTCATEGORYHIERARCHYNAME CATEGORYNAME CATEGORYCODE CATEGORYDESCRIPTION CATEGORYKEYWORDS FRIENDLYCATEGORYNAME ISCATEGORYINHERITINGPARENTCATEGORYATTRIBUTES ISTANGIBLEPRODUCT PARENTPRODUCTCATEGORYCODE PARENTPRODUCTCATEGORYNAME PKWIUCODE
      NIGP ABRASIVES 005 ABRASIVES 000 NIGP
      NIGP Abrasive Equipment and Tools 00505 Abrasive Equipment and ToolsĀ  005 ABRASIVES
      NIGP Abrasives, Coated: Cloth, Fiber, Sandpaper, etc. 00514 Abrasives, Coated: Cloth, Fiber, Sandpaper, etc.Ā  005 ABRASIVES
      NIGP Abrasives, Sandblasting, Metal 00521 Abrasives, Sandblasting, Metal 005 ABRASIVES
      Shirley Adams
      Solution Architect
      AKA Enterprise Solutions
      New York NY
    • Daniel Zook
      July 25, 2019 at 8:36 AM
      I spoke too soon.Ā  Some categories are importing just fine, but others from the same import are failing with the same error: “Root node already exists.”Ā  I set a break point and stepped through the code and found that the problem occurs when AX can’t find the specified parent category.Ā  I confirmed that the parent category wasn’t imported, but I can’t figure out *why* it wasn’t imported.Ā  I have the source data sorted so that the top level categories are imported first, and then the 2nd level, 3rd level, etc.Ā  No error is thrown when the parent categories are skipped.Ā  (Not all parents are skipped, just some.)
      If I import one level at a time, everything works just fine.Ā  Unfortunately, AX won’t let you have the same entity multiple times in the same processing group, so this work around is cumbersome (I would have to run four different processing groups), but if that’s the only way to do it, so be it.
      If anyone else has experienced this or knows where to look for help with this, I would appreciate it if you would share.
      Thanks.
      Daniel Zook
      Director of IT
      Lehman’s
      Dalton OH
    • Carol Holmes
      July 26, 2019 at 9:00 AM
      Daniel-
      Just a thought about this. I wonder if you already have the hierarchies set up in a different legal entity? We are in the midst of adding a new legal entity and I had noticed that our Sales and Expense Category Hierarchies were already in the new legal entity. I’m not sure if these are shared by default or if it might be in the Purchasing Policies.
      Carol
      Carol Holmes
      Business Systems Supervisor
      Vesta Solutions, Inc.
      Temecula CA
    • Daniel Zook
      July 26, 2019 at 1:45 PM
      Thanks for the suggestion.Ā  We only have one legal entity though, so I don’t think there is a conflict there.
      Daniel Zook
      Director of IT
      Lehman’s
      Dalton OH
    DSC Communities replied 6 years, 10 months ago 1 Member · 0 Replies
The discussion ‘DMF/DIXF Product category hierarchy: Import does not work’ is closed to new replies.
