Brazilian vendor bank account format
  • Brazilian vendor bank account format
    Posted by DSC Communities on May 28, 2021 at 10:30 am
    • Stacy Black
      May 28, 2021 at 10:30 AM
      Hi All,
      I am setting up some Brazilian vendors and need to add their banking information.Ā  I have their SWIFT and account number but D365 (10.0.16) keeps telling me that the format is incorrect – “Invalid bank account format. Expected format is “<Bank code> <branch number> <account number>”.Ā  I have reached out to a Brazilian consultant and she confirmed that Brazil has an account format that goes something like this:Ā  341-1234-654321 and this didn’t work.Ā  I have tried without the dashes and using the <> like the error message and nothing works.
      I could use your assistance!!
      Stacy Black
      Senior Finance Consultant
      MCA Connect
      Mukilteo WA
    • Jake Milford
      January 18, 2022 at 6:08 PM
      I think this will work for you. What worked for me: 341 1234-6 5432-1
      The IBAN verification structure says that the account number will start in position 18 and be 10 characters.Ā  Routing number will start in position 5 and be 13 characters.
      While their example isn’t super clear, I was able to get it to work by adding spaces and dashes.Ā
      Requires 3 digits, space, 1-4 digits, dash, 1-12 digits, dash, 1-2 digits.
      https://fix.lcs.dynamics.com/Issue/Details/1565362?bugId=513408&dbType=3&qc=5675d8c788e3f093a2ca1b6c4b5df5437efd3d58aa1c5d23f76915df3a6e0ec4
      KB number: 4586745
      According to validation source code bank account number must match the following regular expression:
      ^d{3} d{1,4}(-[a-zA-Z0-9]{1})? d{1,12}-[a-zA-Z0-9]{1,2}$
      The error message is due to the validation rules which exists specifically on field Bank account number, which must follow a specific mask:Ā
      237 0264-x 123456789012-xy
      whereĀ
      237 – bank code
      0264 – agency
      x – agency DAC
      123456789012 – accountĀ
      xy – DAC
      The localization requirement does not consider extracting those data from IBAN, but entering manually.
      Jake
      AX 2012 R3 CU 10
    DSC Communities replied 5 years ago 1 Member · 0 Replies
The discussion ‘Brazilian vendor bank account format’ is closed to new replies.
