Add new fields to entity for BYOD export
  • Add new fields to entity for BYOD export
    Posted by Unknown Member on October 28, 2020 at 10:31 am
    • Stuart Broach
      October 28, 2020 at 10:31 AM
      Good Morning All,
      I have a question regarding a data export project I have. I have been asked to add two fields (PO and Vendor ID) to the Project Actuals Entity. I can see in the data management module how to access the mapping details for the entity; but when I create a new line, I can select the staging field I want but it has nowhere to map to. My questions are:
      1. Can I just add a column to my table in the BYOD and have ERP recognized I did so so that I can then map to it (probably not)?
      2. Is this doable with the BYOD option or is this something that is geared towards an entity store in a data lake?
      Thanks in advance.
      Stuart Broach
      Medicago
    • Ben Morgan
      October 28, 2020 at 2:07 PM
      HI Stuart,
      Adding to entities (or creating new ones) for BYOD or other purposes typically requires working in Visual Studio – something like these steps: https://d365byjp.blogspot.com/2019/12/extending-standard-data-entity-to-add_2.html
      Ben Morgan
      M3 Engineering & Technology Corp
    • Stuart Broach
      October 28, 2020 at 4:00 PM
      Thanks Ben! That makes sense. I’m still new to D365 and trying to piece this together in my head. I wish I could just go into SSMS and create the field since visual studio is doing the same thing. Is there code that needs to be deployed?
      Stuart Broach
      Medicago
    • Ben Morgan
      October 28, 2020 at 6:11 PM
      For something as simple as just adding fields, or even exposing an entire table, there really isn’t any coding, but you have to understand what model to put the new objects in and also understand Azure DevOps or whatever your site uses for code management.Ā  The steps are pretty similar to the link I sent above, though there will always be variations depending on what you are trying to accomplish.Ā  There are many more walkthroughs and blogs like this that address different aspects or variations of the process.Ā  Microsoft has some good documentation as well – for example here: https://docs.microsoft.com/en-us/dynamics365/fin-ops-core/dev-itpro/data-entities/build-consuming-data-entities
      Ben Morgan
    Unknown Member replied 5 years, 6 months ago 1 Member · 0 Replies
The discussion ‘Add new fields to entity for BYOD export’ is closed to new replies.
