Un-Editable Unit Cost Field
  • Un-Editable Unit Cost Field
    Posted by Unknown Member on September 19, 2019 at 12:01 pm
    • Caryn Binns
      September 19, 2019 at 12:01 PM
      ?Hello!
      Can someone explain why the Unit Cost field in the item card is un-editable and greyed out for some items and not others?Ā  Trying to update the Unit Cost field based on a Standard Cost Roll-Up.Ā  This particular item is a Prod. Order item and we use FIFO for our rollups.Ā  See attached picture.
      Thanks in advance. šŸ™‚
      Caryn Binns
      Operations Coordinator
      Busch Systems International Inc
      ON
    • Alfredo Zelaya
      September 19, 2019 at 12:41 PM
      Hello!
      Do you have the “Replenishment” set to “Assembly”?
      Alfredo Zelaya
      Sr. Systems Analyst
      Megadyne Americas LLC
      Fairfield NJ
    • Caryn Binns
      September 19, 2019 at 12:45 PM
      Hi Alfredo,
      No, I have it set to Prod. Order.
      Caryn Binns
      ON
    • Alfredo Zelaya
      September 20, 2019 at 8:03 AM
      Caryn
      I can’t replicate that situation on my test instance. I truly hope another member has insight on this situation. The only I can see when the Unit Cost is greyed out is when the Costing Method is changed to Standard. Every other (except specific – that requires an Item Tracking set to SN) leaves the Unit Cost open for modification. ?
      Alfredo Zelaya
      Sr. Systems Analyst
      Fairfield NJ
    • Michael Carr
      September 20, 2019 at 8:42 AM
      I believe a production order item requires the item unit cost is rolled up from the BOM and it’s related costs.
      Michael Carr
      VP , Finance
      Philadelphia Scientific LLC
      Montgomeryville PA
    • Caryn Binns
      September 20, 2019 at 8:56 AM
      Hi Michael,
      Than?k you for your response.Ā  Please see attached.Ā  When I preform a Standard Cost Roll-up the cost populates in the Standard Cost field and then I have to transfer the cost into the Unit Cost field currently.Ā  I feel like this is not the best practice, but it is what I have to do currently for the proper cost to be pulled onto quotes and sales orders.Ā  See attached snip it of another item that is an assembly and the Unit Cost field is at $0.00 and I am not able to update it.
      Thanks again!
      Caryn Binns
      ON
    • Michael Carr
      September 23, 2019 at 8:45 AM
      Caryn,
      1. This setup looks odd indeed. Cost method is FIFO and yet standard cost is filled in but greyed out. Actual cost is $0 and greyed out. This would indicate a history that is muddled somehow. An assembly order with FIFO should show up with NO standard Cost.Ā
      2. Have you been running Adjust Entries – Standard Cost?
      Michael Carr
      VP , Finance
      Montgomeryville PA
    • Michael Heatherly
      September 20, 2019 at 12:47 PM
      Navision intended the Unit Cost field to be a derived field result.
      if you have a purchase order receiptĀ
      Direct Unit Cost Excluding tax less a Line Discount % calculates the Unit Cost $.
      If you make the Unit Cost$ field editable, Navision will stillĀ  calculate the formula above and it will post what you manually enter into the Unit Cost$ fieldĀ  and post to a hidden field (Our VAR sat silent to it) and will throw the difference toĀ
      an Indirect Cost Percentage .
      Michael Heatherly
      controller
      Lesman Instrument Company
      BENSENVILLE IL
    • Crystal Tollison
      September 20, 2019 at 8:54 AM
      Hi Caryn,
      My experience has been that the Unit Cost field is editable until you make a posting using that Item Card. At that point, the system wants to calculate this value based on the postings to the Item Card so it is no longer editable. Best practice is to populate the Unit Cost with a value before using it. If you know the expected value of the item you can be exact however just something in the ballpark is better than zero.Ā  This fieldĀ calculates the weighted average cost of on-hand inventory and will be more accurate if there is a value to start with versus aĀ zero value.?
      Microsoft likes to sneak in little changes here and there so this might not hold true to your particular version of NAV but this has been the case for all versions I have worked with during the past 20+ years.
      Crystal Tollison
      Consultant
      ArcherPoint Inc.
      Lawrenceville GA
    • Amanda Mayer
      September 23, 2019 at 7:02 AM
      Have transactions already occurred for the items where the Unit Cost is grayed out? ?With FIFO, the unit cost is based on the receipts and or outputs that have occurred and should NOT be editable. If you want to change the value of a FIFO item, you should be using the revaluation journal.
      Amanda Mayer
      New View Strategies
      Milwaukee WI
    • Ted Johnston
      September 24, 2019 at 11:15 AM
      We have a similar issue but use Average Cost. NAV updates the Unit Cost field on the item card each time it recalculates Average Cost.
      As Average Cost is not trivial to understand, this drove sales crazy. Especially for rarely sold items. They wanted to be able to update the item when the vendor changed their pricing and have that used on the Sales Order.
      I did a simple mod to the sales line table to bring the Standard Cost field off the item card into the Unit Cost field on the Sales Line.
      Now I just have to periodically explain why the SO had a profit % of x but the invoice is y. When arguments break out, it is between sales and accounting. The company also has the option of calculating commission off the expected profit or the actual profit.
      I do envy companies with Standard Costing……
      Ted Johnston
      IT Director
      Streicher’s
      Minneapolis MN
    • Caryn Binns
      September 24, 2019 at 3:09 PM
      ?Hi Amanda,
      Yes, I have been using the Revaluation Journal and running the Cost Adjust first as recommended.Ā  However this particular item will not populate on the Revaluation Journal and I am not understanding why.Ā  Is there a reason why some items may not populate on the Revaluation Journal, even will I filter to the specific item number I want to adjust?
      Caryn Binns
      ON
    Unknown Member replied 6 years, 8 months ago 1 Member · 0 Replies
The discussion ‘Un-Editable Unit Cost Field’ is closed to new replies.
