Rapidstart Export error in NAV 2016
  • Rapidstart Export error in NAV 2016
    Posted by DSC Communities on February 8, 2018 at 5:15 pm
    • Vivian Mosher
      February 8, 2018 at 5:15 PM
      Hello!
      I am hoping someone can assist with an issue I am having in NAV 2016.Ā  I am trying to do an update to a table using Rapidstart. When I get to the step where I try to Export to Excel, I receive the following error:Ā
      A call to MicrosoftDynamics.Nav.OpenXml.Spreadsheet.WorkbookWriter.Dispose failed with this message: File contains corrupted data.
      I have never come across this issue before when using Rapidstart.Ā  To resolve this issue I created a new table that is an exact duplicate of the original table.Ā  I was able to use Rapidstart with the new table with no issues.Ā  I then saved the new table as the old one.Ā  That did not fix the error.
      Has anyone had this issue and fixed it?Ā  Please help!
      Thank you in advance!
      Vivian
    • Kyle Hardin
      February 9, 2018 at 8:03 AM
      When you say that the new table is an exact duplicate of the original table, what does that mean? Does that mean the fields and data types are the same, or did you copy every single row from old to new?
      In the past when I have gotten data errors during export, it usually is the data itself. Meaning that a field contains a character that can mess up an export, such as double quote, comma, less-than (<), greater-than (>) etc.
      You can turn on the debugger before the export and probably figure out which exact record in the table the export dies on.
      Kyle Hardin
      NAV Developer
      ArcherPoint Inc.
      Atlanta GA
    • Crystal Tollison
      February 9, 2018 at 9:31 AM
      ?Diddo what Kyle said.Ā  Take a small sample of only five lines of data for example. If that imports in without the error, it is most likely data related and not the import. Ā AsĀ he points out, Excel does not like the symbols and such in it’s data.
      Crystal Tollison
      Consultant
      ArcherPoint Inc.
      Lawrenceville GA
    • Vivian Mosher
      February 11, 2018 at 10:16 AM
      I ended up deleting the original table (50001) and then creating a new table and saving it using the same ID (50001).Ā  There are only two fields, Code and Text.Ā  There is no C/AL code or no strange configurations.Ā  Just a straight forward table.Ā  Next, I entered one line of data, text only. No characters at all.Ā  I received the same error message.Ā  This table was already created before we upgraded to NAV 2016 from NAV 2009 r2.Ā  Could that have anything to do with it?
      Thank you!
      Vivian
    • Kyle Hardin
      February 12, 2018 at 8:10 AM
      I don’t think upgrading a table from 2009R2 to 2016 would have anything to do with this problem.
      Can you post a screen snap of the configuration package?
      Do you have the checkbox Exclude Config. Tables set to Yes?
      Kyle Hardin
      NAV Developer
      ArcherPoint Inc.
      Atlanta, GA
    • Vivian Mosher
      February 12, 2018 at 10:33 AM
      Thanks for taking a look!Ā  I do have Exclude Config. Tables: checked.
      Thank you!
      Vivian
    • Jenn Claridge
      February 13, 2018 at 8:31 AM
      ?Hi Vivian
      When I have seen this in the past it looked like the export file was corrupted and lost some XML Mapping.
      What I have done is just a clean export to excel and then copy and pasted the data from my original sheet. Just paste in the table data though, the new export will have the package information and XML it needs. After that, I would reimport and it has always worked.
      Jenn Morton
      Manufacturing Consultant
      Sabre Limited
      Cambridge Ontario Canada
    • Vivian Mosher
      February 15, 2018 at 10:55 AM
      Thank you to everyone that replied!Ā  It turns out that this is an Upgrade issue that Microsoft is aware of and fixed in theirĀ Cumulative Update 13 for Microsoft Dynamics NAV 2016 (Build 47256) – IDĀ 381067.
      Thanks to Kyle for figuring this out!!!
      https://support.microsoft.com/en-us/help/3202891/cumulative-update-13-for-microsoft-dynamics-nav-2016-build-47256
      Thank you!
      Vivian
    • Franz Kalchmair
      February 25, 2018 at 10:38 AM
      please checkout
      –Ā https://community.dynamics.com/nav/f/34/t/148134
      –Ā https://dynamicsuser.net/nav/f/developers/92068/error-at-the-time-of-report-to-generate-in-export-to-excel
      for a solution.
      Franz Kalchmair
      Microsoft MVP
      Senior Consultant
      Vienna, Austria, Europe
    DSC Communities replied 8 years, 3 months ago 1 Member · 0 Replies
The discussion ‘Rapidstart Export error in NAV 2016’ is closed to new replies.
