Quarantine Material for an Annual Stock Rotation
  • Quarantine Material for an Annual Stock Rotation
    Posted by Unknown Member on March 15, 2019 at 6:07 pm
    • Michael Heatherly
      March 15, 2019 at 6:07 PM
      Proposed Stock Rotation procedureĀ
      When other Navision usersĀ  prepare annual stock rotations, do you process the record all the way through to a Posted Purchase Credit Memo
      prior to shipping?
      We have several of our major suppliers that permit annual stock rotations
      We send an initial list of items to the Suppler that we are requesting a Stock Rotation on,Ā  based on their response regarding items approved for return:
      We will send the material back on a Return Order.
      Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā  The return order must have comments added
      Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā The Date the Shipment took place
      Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā  The miscellaneous shipment number from Lanham E-Ship
      Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Every Tracking Number involved with the return
      Once at the factory Suppliers can adjust / reject items for several reasons
      Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā  Item is out of warranty
      Ā Ā Ā  Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Packaging is determined to look used not in as new condition
      Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā  Item requires rework we were not aware of Ā
      Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Their package count differs from ours’
      Ā  Ā  Ā  Ā  Ā  Ā  Ā  Ā  Ā  Ā  Ā  Ā  Ā  Ā  Ā  Ā  Ā  Ā  Ā  Ā  Ā  Ā  After review additional Items will only be accepted at a higher restock charge than initially quoted
      We will amend the return order as needed (remove line items and / or change quantities, add restock charge charges etc ) put the rejected items back into stock if we determine they are still saleable at some discounted value, write-off the items totally rejected and scrapped at the factory.
      The Supplier gives us an RMA control number and shipping paperwork for the items to be returned to us.
      (The item quantities will stay in a quarantined Bin Location)
      The return order will be adjusted to what is finally accepted, and or evidenced by the Supplier Credit Memo.
      The Purchase return credit will be updated and posted at values that match the Supplier’s Ā Credit Memo.
      It can be taken immediately on the next check run, since it will be created with the Supplier Credit Memo# as the External Document Number
      Note
      Item reclass journals will be used to move the items to a restricted Bin Location
      The Bin Location will be the Vendor Purchase Code, prior to the -P (Purchase Vendor Suffix) and the RMA##########
      Navision allows 20 characters for a Bin Location
      (Note this not an extra step because you have to use item reclass journals to move the items to a restricted bin location anyway)
      Our Var suggested we quarantine the product to remove it from
      Ā Example of Bin LocationĀ
      HONEFR RMA5243504508
      Thank you
      Michael Heatherly
      controller
      Lesman Instrument Company
      BENSENVILLE IL
    Unknown Member replied 7 years, 1 month ago 1 Member · 0 Replies
The discussion ‘Quarantine Material for an Annual Stock Rotation’ is closed to new replies.
