flow fields on item Ledger Entries
Posted by DSC Communities on April 24, 2018 at 5:40 am-
Christine Cook
MemberApril 24, 2018 at 5:40 AM
Hi allI have put a flow fieldĀ for ‘item ledger No.’ on Table17 ‘G/L Entry’ andĀ Page 20 ‘General Ledger Entries’ from Table 5802 ‘Value Entries’ calling it ‘Item Ledger No’Ā usingĀ Document no as the relationship.Ā Can anyone see this causing any issues?Ā I have done this on my test DB and it all seems to work well but just wanted to check before putting it on live.
regards
Christine——————————
Christine Cook [Designation]
Procurement International Ltd
Wokingham
I can’t think of a reason why a flowfield would cause an issue besides slowing things down a little.Ā There is an index for Document No. on the Item Ledger Entry table so you should be all set.Ā I would typically make the flowfield hidden by default but again only for performance reasons.
Jason Wilder
Senior Application Developer
Stonewall Kitchen
York ME
I agree. Displaying the flowfield right away might slow down the loadingĀ of theĀ page. So, if you want to test the performance, I would suggest keepingĀ it hidden and then display it after the page is opened so you can verify that the
flowflow field is not causing any delays.– Meenakshi
Meenakshi Singh
Home Market Foods, Inc.
Norwood MA
Franz Kalchmair
MemberApril 25, 2018 at 3:56 PM
flowfields always can lower the perfomance especially in ledger entries, because ledger entries can be a huge amount. so each posting, saving, loading will be slower before adding that field.
best you give it a try with a copy of the live db as your test db. measure the load time of the page before adding the field and after adding. if load time is ok for you, then it’s ok.
other solution would be a normal integer field, which is filled when posting. existing records can be filled using a batch job.——————————
Franz Kalchmair
Microsoft MVP
Senior Consultant
Vienna, Austria, Europe
Marije Brummel
MemberApril 27, 2018 at 3:46 AM
Frank,You know I have a lot of respect for you knowledge, but the info you are sharing here is unfortunately wrong.
Flowfields are not getting slower over time, at least not by design.
To guarantee performance on FlowFields NAV has SumIndexFields. When properly setup NAV will maintain a seperate table, in SQL a View with an Index, to make sure the flowfield is always fast.
In the latest versions of NAV FlowFields are calculated using one single SQL Statement. This requires an index strategy which is optimized for Join statements.
Unfortunately these changes, although one of the best platform improvements since sliced bread, cause all SQL knowledge prior to this change obsolete.
In older versions of NAV creating such SumIndexField was mandatory. Microsoft has chanced that to optional, partly on my advise. It means that you first get to try the performance without, and when slow you need to update your index strategy based on your requirement.
In my opinion, indexes should be a seperate object, or extension if you call it that, to a table to require each customer to run on their own indexes without changing table objects.
Mark Brummel
NAVUG All-Star
MVP Microsoft Dynamics NAV
Brummel Dynamics Services B.V.
Olst
Christine Cook
MemberApril 30, 2018 at 5:27 AM
thank you for your advice everyone, I have tested on my test (which is a copy of the live too) the page loads very quickly.Ā I am always cautious with flowfields especially around ledger entry tables——————————
Wokingham
DSC Communities replied 8 years ago 1 Member · 0 Replies -
The discussion ‘flow fields on item Ledger Entries’ is closed to new replies.
