Reply To: Team License
  • Benjamin Baxter
    November 1, 2023 at 8:37 am
    Shana,
    This does not sound like a viable use for the Team Member license. You would be updating to many tables in the process to be allowed by the limitations of the Team Member License. You are likely going to need a Full User License.
    That being said, if you had an ISV solution handling the receiving via a handheld, you could utilize a Device License. In this case, you’ll have additional cost in the ISV software as well as the physical handheld. You may find the efficiency gained may justify the cost of the additional components.
    Your Business Central partner will have their preferred ISV products for this type of scenario, so it might be worth a consultation call to discuss the options with them.
    Best Regards,
    Ben Baxter
    Accent Software Inc
