We have hundreds of assets that need to have their cost basis lowered. Instead of going in one by one and manually adjusting, is there a way to use Integration Manger to adjust them all at once?
—————————— Jacob Dinota Connections Education LLC Baltimore MD ——————————
Michael Taranto, CPA
March 8, 2017 at 11:30 AM
The integration manager with the econnect installed, can import Fixed Assets. It only has an insert mode and not an update. You would then have two options. First, export out your fixed asset information using smartlist or a tool of your choice, make the changes, clear the fixed asset table and then import. Another choice would be to create a macro and use the transfer asset feature under transactions with a word mail merge.
Hope this points you in a direction you can use.
Thanks Mike
—————————— Michael Taranto, CPA President ERP Consulting LLC Pataskala OH —————————— ——————————————-
Jacob Dinota
March 16, 2017 at 10:15 AM
Hi Mike,
When you say we need to clear the fixed asset tables, what do you mean by that? Are you saying that we need to basically delete all of our fixed assets and then reupload them all back with the corrected information?
Also, how is life to date depreciation affected by all of this?
Thanks for your help, Jake
—————————— Jacob Dinota Connections Education LLC Baltimore MD —————————— ——————————————-
If you use the eConnect version of the Asset General Information Destination, you can set up an Integration. The following fields are required (in addition to Cost Basis which is what you want to adjust):
Asset ID
CHAR(15)
Asset ID Suffix
NUMERIC
Description
CHAR(40)
Class ID
CHAR(15)
Book ID
CHAR(15)
Place in Service Date
DATE
Depreciated to Date
DATE
Cost Basis
NUMERIC
If you can export the existing Assets and then add the necessary information, you should be able to import this back in. Hope that helps.
—————————— Blair Christensen Database Administrator Oppenheimer Companies, Inc. Boise ID —————————— ——————————————-
