SSRS report not showing all fields
Posted by DSC Communities on March 16, 2017 at 5:48 pm-
Sergios Rahmatoulin
MemberMarch 16, 2017 at 5:48 PM
Hi,I have an SSRS that shows some numbers bases on Year and Quarter (I have created parameters for those). When I run the report I have no issue with Year but it only works for Quarter 1. If I run this in the Query Designer then it works for both Year and Quarter with no issue.
Here is my code:
IF @Quarter = ‘1’
(select EMPLOYID as EmployeeID,SUM(Q1Gross) as Q1Gross,SUM(Q1fedWages) as Q1fedWages,(SUM(Q1Gross)-SUM(Q1FedWages)) as “Gross – FedWages” from (select EMPLOYID, GROSWAGS_1 + GROSWAGS_2 + GROSWAGS_3 Q1Gross,
Federal_Wages_1 + Federal_Wages_2 + Federal_Wages_3 as Q1fedWages
from UPR00900 where YEAR1 = @Yearunion ALL
select a.EMPLOYID,-(MTDWAGES_1 + MTDWAGES_2 + MTDWAGES_3),0 as wages from UPR30301 as a inner join UPR00500 as b on
a.EMPLOYID = b.EMPLOYID and a.PAYROLCD = b.DEDUCTON and a.PYRLRTYP = 2
where a.YEAR1 = @Year and b.SFRFEDTX = 1
union allselect a.EMPLOYID,+(MTDWAGES_1 + MTDWAGES_2 + MTDWAGES_3),0 as wages from UPR30301 as a inner join UPR00600 as b on
a.EMPLOYID = b.EMPLOYID and a.PAYROLCD = b.BENEFIT and a.PYRLRTYP = 3
where a.YEAR1 = @Year and b.SBJTFDTX = 1)x group by EMPLOYID having sum(Q1Gross) <> sum(Q1fedWages))
ELSE IF @Quarter = ‘2’
(select EMPLOYID as EmployeeID,SUM(Q2Gross) as Q2Gross,SUM(Q2fedWages) as Q2fedWages,(SUM(Q2Gross)-SUM(Q2FedWages)) as “Gross – FedWages” from (select EMPLOYID, GROSWAGS_4 + GROSWAGS_5 + GROSWAGS_6 Q2Gross,
Federal_Wages_4 + Federal_Wages_5 + Federal_Wages_6 as Q2fedWages
select a.EMPLOYID,-(MTDWAGES_4 + MTDWAGES_5 + MTDWAGES_6),0 as wages from UPR30301 as a inner join UPR00500 as b on
union allselect a.EMPLOYID,+(MTDWAGES_4 + MTDWAGES_5 + MTDWAGES_6),0 as wages from UPR30301 as a inner join UPR00600 as b on
where a.YEAR1 = @Year and b.SBJTFDTX = 1)x group by EMPLOYID having sum(Q2Gross) <> sum(Q2fedWages))
ELSE IF @Quarter = ‘3’
(select EMPLOYID as EmployeeID,SUM(Q3Gross) as Q3Gross,SUM(Q3fedWages) as Q3fedWages,(SUM(Q3Gross)-SUM(Q3FedWages)) as “Gross – FedWages” from (select EMPLOYID, GROSWAGS_7 + GROSWAGS_8 + GROSWAGS_9 Q3Gross,
Federal_Wages_7 + Federal_Wages_8 + Federal_Wages_9 as Q3fedWages
select a.EMPLOYID,-(MTDWAGES_7 + MTDWAGES_8 + MTDWAGES_9),0 as wages from UPR30301 as a inner join UPR00500 as b on
union allselect a.EMPLOYID,+(MTDWAGES_7 + MTDWAGES_8 + MTDWAGES_9),0 as wages from UPR30301 as a inner join UPR00600 as b on
where a.YEAR1 = @Year and b.SBJTFDTX = 1)x group by EMPLOYID having sum(Q3Gross) <> sum(Q3fedWages))
ELSE IF @Quarter = ‘4’
(select EMPLOYID as EmployeeID,SUM(Q4Gross) as Q4Gross,SUM(Q4fedWages) as Q4fedWages,(SUM(Q4Gross)-SUM(Q4FedWages)) as “Gross – FedWages” from (select EMPLOYID, GROSWAGS_10 + GROSWAGS_11 + GROSWAGS_12 Q4Gross,
Federal_Wages_10 + Federal_Wages_11 + Federal_Wages_12 as Q4fedWages
select a.EMPLOYID,-(MTDWAGES_10 + MTDWAGES_11 + MTDWAGES_12),0 as wages from UPR30301 as a inner join UPR00500 as b on
union allselect a.EMPLOYID,+(MTDWAGES_10 + MTDWAGES_11 + MTDWAGES_12),0 as wages from UPR30301 as a inner join UPR00600 as b on
where a.YEAR1 = @Year and b.SBJTFDTX = 1)x group by EMPLOYID having sum(Q4Gross) <> sum(Q4fedWages))
The issue has to do with the If statement, I’m sure, but I don’t know how to fix it. The report only shows the fields from the first If statement.
Can someone help please?
Sergios Rahmatoulin
Systems Analyst
Hope Community Resources, Inc.
Anchorage AK
Steve Erbach
MemberMarch 16, 2017 at 6:58 PM
Sergios,As far as SQL code goes, your query doesn’t require the ELSEs. Each IF statement is checking a different possibility for the same variable so they’re mutually exclusive.
Since our company doesn’t use the Payroll module, I simplified your query to test its logic:
DECLARE @Quarter CHAR(1) = ‘3’;IF @Quarter = ‘1’ (SELECT @Quarter AS Answer) ELSEIF @Quarter = ‘2’ (SELECT @Quarter AS Answer) ELSEIF @Quarter = ‘3’ (SELECT @Quarter AS Answer) ELSEIF @Quarter = ‘4’ (SELECT @Quarter AS Answer)The Answer is ‘3’ in this case. If you remove the ELSEs you get the same result.
As far as the report only working for Q1, that’s because your report’s Dataset only expects the Q1 field names from the 1st IF statement. You have to change the query so that the “Q1Gross” field is just “Gross” and the Q1fedWages field is FedWages. Ditto for each of the IF statements. Always return the same field names, not different ones depending on the Quarter.
Sincerely,
“Sparkly” Steve Erbach – Business Analyst & MS Dynamics Platform Administrator
WOW Logistics Company – Appleton, WI
VP for Communication, GPUG WI (Milwaukee) Chapter
GP 2016 (16.00.0439) / MR 2012 CU15
Twitter: @serbach
Welcome to Dynamics!
You do not have permission.
Call Steve. (hat tip: Lou Spevack)
Steve Erbach
MemberMarch 17, 2017 at 11:04 AM
Sergios,In order to differentiate between quarters in your report, I would add a column in each of your IF queries for the quarter. Instead of having field names that differentiate quarters, use a value in a “Quarter” field. Then your SSRS report can utilize the content of that field to let you know which quarter is which.
Twitter: @serbach
Sergios Rahmatoulin
MemberMarch 17, 2017 at 1:50 PM
Guys thank you for all your replies…they were all really good and useful!However, what solved my problem the easiest way was this:
Thank you!
Sergios Rahmatoulin
Systems Analyst
Anchorage AK
Neil Blotske
MemberMarch 17, 2017 at 10:36 AM
In line with what Steve suggested, you could see if this works for you. I only checked to verify this returned data, but haven’t taken the time to validate numbers – there’s my dislaimer . . . and your homework 😉declare @year int = 2016
declare @Quarter int = 2select EMPLOYID as EmployeeID,SUM(Gross) as Gross,SUM(fedWages) as fedWages,(SUM(Gross)-SUM(FedWages)) as “Gross – FedWages”
from (SELECT EMPLOYID, GROSWAGS_1 + GROSWAGS_2 + GROSWAGS_3 AS Gross, Federal_Wages_1 + Federal_Wages_2 + Federal_Wages_3 AS fedWages
FROM UPR00900
where YEAR1 = @Year and { fn QUARTER(LSTPCKDT) } in (@Quarter)union ALL
select a.EMPLOYID,
Case when @Quarter = 1 then -(MTDWAGES_1 + MTDWAGES_2 + MTDWAGES_3)
when @Quarter = 2 then -(MTDWAGES_4 + MTDWAGES_5 + MTDWAGES_6)
when @Quarter = 3 then -(MTDWAGES_7 + MTDWAGES_8 + MTDWAGES_9)
when @Quarter = 4 then -(MTDWAGES_10 + MTDWAGES_11 + MTDWAGES_12)
else 0 end as gross,0 as wages
where a.YEAR1 = @Year and b.SFRFEDTX = 1union all
select a.EMPLOYID,
Case when @Quarter = 1 then (MTDWAGES_1 + MTDWAGES_2 + MTDWAGES_3)
when @Quarter = 2 then (MTDWAGES_4 + MTDWAGES_5 + MTDWAGES_6)
when @Quarter = 3 then (MTDWAGES_7 + MTDWAGES_8 + MTDWAGES_9)
when @Quarter = 4 then (MTDWAGES_10 + MTDWAGES_11 + MTDWAGES_12) else 0 end as fed,
0 as wages
where a.YEAR1 = @Year and b.SBJTFDTX = 1)x group by EMPLOYID having sum(Gross) <> sum(fedWages)
Neil Blotske
KT Connections, Inc.
Rapid City SD
I work with SSRS quite a bit and I would propose a slight adjustment to your query such:
DECLARE @Yr as INTEGER
, @Qtr as INTEGER
select EMPLOYID
, SUM(GrossWages) as GrossWages
, SUM(FederalWages) as FederalWages
, SUM(GrossWages) – SUM(FederalWages) as DIFF
from (
select EMPLOYID
, CASE WHEN @Qtr = 1 THEN GROSWAGS_1 + GROSWAGS_2 + GROSWAGS_3
WHEN @Qtr = 2 THEN GROSWAGS_4 + GROSWAGS_5 + GROSWAGS_6
WHEN @Qtr = 3 THEN GROSWAGS_7 + GROSWAGS_8 + GROSWAGS_9
WHEN @Qtr = 4 THEN GROSWAGS_10 + GROSWAGS_11 + GROSWAGS_12
ELSE 0
END as GrossWages
, CASE WHEN @Qtr = 1 THEN Federal_Wages_1 + Federal_Wages_2 + Federal_Wages_3
WHEN @Qtr = 2 THEN Federal_Wages_4 + Federal_Wages_5 + Federal_Wages_6
WHEN @Qtr = 3 THEN Federal_Wages_7 + Federal_Wages_8 + Federal_Wages_9
WHEN @Qtr = 4 THEN Federal_Wages_10 + Federal_Wages_11 + Federal_Wages_12
ELSE 0
END as FederalWages
from UPR00900
where YEAR1 = @Yr
union ALL
select a.EMPLOYID
, CASE WHEN @Qtr = 1 THEN -(MTDWAGES_1 + MTDWAGES_2 + MTDWAGES_3)
WHEN @Qtr = 2 THEN -(MTDWAGES_4 + MTDWAGES_5 + MTDWAGES_6)
WHEN @Qtr = 3 THEN -(MTDWAGES_7 + MTDWAGES_8 + MTDWAGES_9)
WHEN @Qtr = 4 THEN -(MTDWAGES_10 + MTDWAGES_11 + MTDWAGES_12)
ELSE 0
END as GrossWages
, 0 as FederalWages
from UPR30301 as a
inner join UPR00500 as b on a.EMPLOYID = b.EMPLOYID
and a.PYRLRTYP = 2
where b.SFRFEDTX = 1
and a.YEAR1 = @Yr
union all
select a.EMPLOYID
, CASE WHEN @Qtr = 1 THEN MTDWAGES_1 + MTDWAGES_2 + MTDWAGES_3
WHEN @Qtr = 2 THEN MTDWAGES_4 + MTDWAGES_5 + MTDWAGES_6
WHEN @Qtr = 3 THEN MTDWAGES_7 + MTDWAGES_8 + MTDWAGES_9
WHEN @Qtr = 4 THEN MTDWAGES_10 + MTDWAGES_11 + MTDWAGES_12
ELSE 0
END as GrossWages
, 0 as FederalWages
from UPR30301 as a
inner join UPR00600 as b on a.EMPLOYID = b.EMPLOYID
and a.PYRLRTYP = 3
where b.SBJTFDTX = 1
and a.YEAR1 = @Yr
) x
GROUP BY EMPLOYID
HAVING SUM(GrossWages) – SUM(FederalWages) <> 0
@Yr and @Qtr become the parameters in SSRS you allow the user to select. Because you get to determine the column names in SSRS, I try not to name the columns in my base query using long names or names requiring [] or “”. This version is also much simpler to read and maintain (and probably runs faster).
Blair Christensen
Database Administrator
Oppenheimer Companies, Inc.
Boise ID
DSC Communities replied 6 years, 6 months ago 1 Member · 0 Replies -
