The first problem is: When printing checks, since we started using computer the checks print in reverse order. Example, if the next check is 005 and the last check is 010, when we print them the check 005 is the last check so the voucher number is 010 but printed on check 005 and the first check prints on 010 with voucher number 005. How do I fix this? I tried to readd the named printer, but it doesn’t matter.Â
The second problem is:Â This same named printer (HP All in One) I would like to use the second tray for the system to select the checks, but when I do it inside the named printer, it does not work.
—————————— Adam Ashby LYFE NETWORKS LLC Valencia CA ——————————
Leslie Vail
May 6, 2017 at 9:26 AM
Hi, On the Advanced options window of my printer, I have a choice as to which order the pages are printed. My choices are Front to Back or Back to Front. Your printer may have this option marked as Back to Front. My printer also allows me to choose the paper source when I print. Does your printer have these options? Kind regards, Leslie
—————————— Leslie Vail Accounting Systems Consulting, Inc. Dallas TX —————————— ——————————————-
Leslie Vail
May 6, 2017 at 9:28 AM
Oops, another question. Are you using native GP to print your checks, or are you using Mekorma or a similar software? Leslie
