Reply To: Slowness after SQL downgrade
  • Beat Bucher
    January 17, 2025 at 1:57 pm
    Hi Howard,
    Not sure if you ever figured out your performance issue on your SQL server, but that has not much to do with the grade “Enterprise” vs. “Standard”.. I have downgraded a client from Enterprise to Standard by moving the entire GP instance to a new SQL server and performance wise there was no difference in GP..
    As @David_Morinello suggested, it’s all about the underlying Windows server setup.. Give it enough CPU’s and RAM, and your SQL / GP will run like a breeze. Speedy disks of course are a must..
    HTH.
    Beat
