Reply To: Remove child account from parent
  • Devon Southall
    December 9, 2024 at 3:30 pm
    GP wasn’t designed for this…
    you can hack it in the background (just remove the field on the customer card table in SQL) but you want to be check if there are payments that were done on this child via the parent… basically, you can’t if that was done unless you are willing to remove that history…
    other options is to setup a new customer and use the changer on the ID is desired.
    I can get you queries if you are interested.
