Reply To: Clearing last user
  • David david@winthropdc.com
    November 7, 2024 at 2:18 pm
    As for the Dexterity login dialog, rather than the Dynamics login dialog, this is caused by some custom code or ISV product attempting to access SQL tables before you have actually logged in.<div>
    Please make sure your ISV products are up to date, including GP Power Tools. šŸ˜„ There is a hotfix available.
    This dialog would not look at the Dex.ini settings you mentioned.
    If you cancel that login, it should generate an error with a table name that would help identify the product that is causing the issue.
    Regards
    David
    </div>
