As you have GP Power Tools, you can check the two Dex.ini settings you mentioned in the Dex.ini Settings window.
However, if they are not achieving what you need, then use the Dex.ini Configuration window to clear the SQLLastUser Dex.ini settings in the Global Dex.ini.
