Choose your environment, Company. Use API category 2.0
Table name salesQuoteLines
Permissions won’t be an issue as Power Automate will use Proof Key for Code Exchange (PKCE) behind the scenes. The initiator of the flow logs in with their Entra ID credentials if not already logged in. This is easier to work with and also the safer way of granting permissions since the auth code can only be redeemed by the client that requests it.
Are you using HTTP Get because of on-premises Business Central? That does make it trickier.
