Reply To: Error – Unable to View PO Details
  • Jeff Woodard
    February 19, 2025 at 8:39 am
    Down Accepted answer
    This table is in the BC Sustainability extension (https://learn.microsoft.com/en-us/dynamics365/business-central/finance-manage-sustainability). If your business doesn’t monitor and record it’s environmental impact, you can also uninstall the extension. In our case, that was simpler than adding and maintaining the security settings. Be aware, however, if you make extensive use of configuration packages that it will remove some columns in key tables that may require you to rebuild some configuration packages. As always test in a sandbox environment first.
