Reply To: How to change a report thats run?
  • Tiffany Collums
    October 3, 2024 at 12:27 pm
    If I print the label from the open Item Card, then I get the same GTIN label as yourself. However, if I am in the item list and then select Process, Print Item Label the popup for the Warehouse Insight Item Barcode Label appears and from here I can select my Item No.
    Also, you can global search for Warehouse Insight Item Barcode Label and you can select your item no. from here too.
