There are a wide range of ways this is managed in different companies I have seen over the years and implemented solutions for. Some are using tablets or scanners on the floor that populate with the order or task, sometimes with filters based on types of assignments. Some use sheets or Kanban that travel around. You could use filtered Task lists by Work or Machine Center, a refreshing dashboard on a monitor, a Power App, or Power Automate to send notifications. It’s all very dependent on the type of work being done, the environment, and the process that is most useful to the users without interfering with the workflow or environment.
