Hi Blaine, exactly as you described it this would be a modification to the base functionality, there is no way to automatically adjust output based on lot criteria. However, if you did something like included a reference to the length difference in your lot numbering, or two different units of measure for the item, when the total component need is calculated the users could see from the components/lots list what the requirement would be (i.e. total output need is 100FT so I can select 4 * 25FT lots or 5*20FT lots). Depending on the whole process you may also be able to use the Calculation Formula = Length on the Production BOM for a quantity suggestion.
