One of my clients also had the issue with needing to set up the blank location in the Inventory Posting Setup. It appears that even though you are using direct transfer, the system is still going through the normal transfer order process where it moves the product from the Transfer-From location to the Intransit Location and then to the Transfer-To location. Since the intransit location is blank for direct transfers, the system errors unless you have the blank location set in the posting setup. Bad design. The direct transfer feature should bypass that part of the code and transfer the inventory directly from the “from” location to the “to” location.
